LED Dual Light / Offroad Light Wiring Harness
freerider15
FoCo, Crawlorado
I've got ~15 pairs of these still in packaging from being a former LED Vendor. At this point, just looking to make more room in the shop, and I don't have plans for their use (have several pairs saved for myself already).
They're meant to connect two lights (e.g. light pods). Each connector leg is rated to 180W.
Harnesses have:
- Weatherproof / waterproof connectors (DT Style, but other connectors can be spliced on)
- On/Off Switch
- Blade Fuse and Fuse Holder (30 amp fuse)
- Bosch Style 5 Prong Relay
- Ring Terminals for Power/Ground Connections
- 10 Feet of Wire between Light Connector and Relay
- 10 Feet of Wire between the Relay and the On/Off Switch
$10 each, located in Fort Collins just Northwest of CSU.
***Note: I do have some pairs that were opened and used for demonstration. Some might be missing a relay or switch, some might have everything. $5 each on those, first come first served.
Pictures in CL Ad here:
https://fortcollins.craigslist.org/pts/d/fort-collins-led-dual-light-offroad/7428456325.html
