biggnate31887
- massachusetts
i have a 99 xj, just changed the passenger side front u-joint. Now the gear oil is comin out of the axle tube! is it possible that i ruined the inner seal? or could I have bent the outer oil slinger causing it to leak? the axle went in smoothly so i suspect the oil slinger.
