leaking from front axles
90BigBlueXJ
North Texas
Well I have sprung a leak at the passenger side front axle. Diff/Gear fluid has made a small puddle under the Jeep. Is this the bearing seals? Or something more drastic? I did just replace the fluid in the diff's about a week before the leak sprung, could I have overfilled - I use the finger test in the draing hole and it was at the same level I always fill to...I thought :-)
I plan on taking it in to get fixed (since I am trying to finish the Harley and Suburban projects) instead of attemting it myself. I have never had this problem before so is there anything else I should look at while their in there?
Jeep details
90 XJ 6cyl, auto
5.5 lift
32's on Dana 30 front and 35 rear with
4.56's front open and rear locked (done in 2002 just about a year ago)
Thanks
Steve
I am assuming that you have the disconnect front axle. The seal is jusdt inside the disconnsct to the left as you look into it. It is a PITA to replace, but, wiht a little patiance and the right tools should only take an hour or so.
Let me know if you want more info on how to DIY.
Rev
Hey thanks for the link to drivetrain direct, that's where I got the diff stuff. I am ordering those tubes seals, thats probably the best thing I have ever seen for a Dana 30. I guess I am just going to do the install myself and take a break from the other projects to save a bit of cash. I generally try to keep the projects to 1 at a time but I gotta get the bike back up to enjoy a little summer fun and the Suburban is nearly complete except for a few mods to the exhaust.
Thanks guys
