Blatant said:
Howdy, all. If a couple of you front leaf-sprung guys could measure your spring center-pin to center-pin distance, I'd be much appreciative. Thanks.
Dion
Depends on what springs your using
I would not do an off set spring second time around.
Use a centered pack like a YJ leaf, Toyota rear pack, or a Wagoneer front (2in off set)
Copy-Pase from my notes:
JC Whitney 76-92Wagoneer Front 7 leafs #07AU2048P $99 each free shipping some times Dimensions:
Free Arch: 7" @ pin
1.81in leaf pack thickness, 8.81in from pad to eye height
Eye to eye (not following the spring): 44 9/16
Eye to eye (following arch): 48 1/8
TO Center pin. 22.5/24.5, 2in off set
1-1.5" of lift over stock YJ leafs.
The 7 leaf has the capacity of 1335lbs
used stock '70s waggoneer front..........200lb/in
Rancho 44044: 2.5in lift 76-92Wagoneer 7 leafs, $101-125 each
300#sq/in
Free Arch: 8.45" @ pin
1.68in leaf pack thickness, 10.13in from pad to eye height.
Eye to eye (not following the spring): 43.64
Eye to eye (following arch): about 48in
2.5in of lift over stock YJ leafs.
Rancho 44050 (jeep yj 2.5").................175lb/in
old Rancho 4" for toyota.......................300lb/in
BDS 4" waggy front springs Part:004402 are 450 lbs./in (7 leaf if i remember right) $81 each $162 a pair
BDS 3.5in YJ leafs, Part: 004351 Front
BDS 3.5in YJ leafs, Part: 004359 Rear
Rusty's 3.5"-4" waggy fronts springs are 5 leaf 310 lbs/in $88 each $175 a pair
Toy leaf dimensions:
http://www.tennessee4x4.com/toyota/misc__spring_information.htm
80-88 Toy rear 48" 20.5" 27.5" 2.36" SOA (SR5 1985 is 280lb/in)
Toyota front 45" 22.5" 22.5" 2.36" SOA
80-85 Rancho 3" Toyota front 45.12" 22.56" 22.56" 2.36" SOA
SkyJacker 5" Toyota front 46" 23" 23" 2.36" SOA
Mazda rear (?? year) 52" 26.5" 25.5" 2.36" SUA
80-88 Toy 4" SkyJacker Rear 49" 21" 28" 2.36" SOA
80-88 Toy 5" SkyJacker Rear 49.5" 21.25" 28.25" 2.36" SOA
89-95 Toy Rear 51" 21.5" 29.5" 2.36" SOA
84 Mazda 2wd rear 51.5" 25.5" 26" 2.36" SUA
84 Isuzu Trooper II rear 47" 21" 26" ??? SUA
Jeep YJ Front or Rear 45" 22.5" 22.5" 2.50" SUA
Pro Comp Jeep YJ 2.5" Lift 46" 23" 23" 2.50 SUA
85 S-10 rear 54" 26" 27" 2.50" SUA
83 Ford Ranger 2wd rear 57" 25.5" 31.5" 2.50" SUA
76 Jeep Wagoneer 4wd front (6 leaf) 48" 24" 24" 2.50" SUA
89 Chevy 2wd rear 63" ?? ?? 2.50" SUA
76-92 Wagoneer Rancho 44044 47.00 22.9" 20.8" 2.50" SUA
76 Jeep Wagoneer 4wd rear (6 leaf) 57" 26" 31" 2.50" SOA
84 Jeep Cherokee rear (4 leaf) 52.5" 23.5" 29" 2.50" SOA
87-95 dakota Dakota rears 2.5" wide use Xj main leaf and Dakota leafs net 3.5inlift
