Lares Steering box question
Looks like its just your run of the mill rebuild to me. It should stop the leaks, as far as how much tigher it will be, thats subjective, depends on how bad your existing steering box is. I imagine it will be as tight as an OEM box, perhaps a tiny bit less.
I don't know if your expecting a steering response like modern rack & pinion systems in new cars or if your old box is falling apart. The recirculating ball steering boxes are never going to give you the feedback that a rack&pinion systems does, sure they can be tight, but if you want steering feel like a modern sports sedan, your not going to get it.
You can give the little pre-load screw on your existing box a 1/4 to 1/2 a turn, that could tighten up the steering some. Don't over do it, you'll chew up your steering box if you turn that screw too far.
As well, if your looking for a cheap fix, NAPA and others, sell seal kits to replace the seals on the box to stop the leaks. Thats not a garuantee, since there could be wear on the shafts, etc that will still cause it too leak with brand new seals, but most likely it stop the leaks, or at least reduce the leaks greatly.
I read some where on here months ago the old boxes were designed with a bit more turn lock to lock and the remanufactured and newer boxes are tighter. Just wondering if this is true and if Lares is the decent brand.
Thats steering ratio, the amount of turn in vs. out, and yes, its generally accepted the lower the ratio (a.k.a. a quicker steering ratio), the more responsive the steering box is.
Tightness refers to lash, or how much slop is in the steering box, i.e. you can turn the steering wheel a 1/4" left or right, before the front wheels actually start to turn. The lash is from wear, and a worn steering box is often refered to as LOOSE, and new box as TIGHT. So thats what I thought you were getting at, how tight it is.
Again, you may know this, but even a recirculating ball steering box with a quicker ratio is still not going to provide the feedback or response that you feel in some of the sporty rack & pinion steering equipped vehicles, so don't get your hopes up too high, thinking a new steering box is going to make your XJ steering feel like the steering in a BMW.
A quicker ratio box is most likely only going to be an incremental improvement in response.
Aside from the leak, slop is the current issue. I'm not looking for a sports car feel. I just don't want it wandering all over the freeway. All my rod ends and joints are good so a new box should help out.
Bad sway bar bushings, bad shocks, bad alignment, bad tires can cause the car to wander all over the freeway. With the motor off, standing outside the car, looking at the front wheel as you grab the steering wheel and move it back and forth.
Watch closely, at the rim, not the tire (it will flex and you won't see the outside edge of the tire move) a fraction of an inch of movement of the steering wheel should cause a tiny movement of the rim, barely enough to notice unless your looking close. If you get this, then your box does NOT have a lot of slop. If you can turn the wheel back and forth a half inch or more and not get any movement at the rim, yea you've got slop.
Tightening the pre-load screw a 1/4 turn can help a lot, but your right the real fix is to get a new box.
I have a 87xj, I recently replaced the steering gear w/ a unit out of a totaled 97xj. I hadn't realized just how worn out the stock box was. World of difference, Tracks straighter, doesn't seem to wander as much. Probably as big an improvement as the crossover steering.
A quick test to see just how much play is in the steering box and/or the column, is to take a small block of wood and a C clamp and clamp the pitman to something solid. Twist the wheel left and rignt and watch closely. I usually do it without the motor running.
It's often a combination of things, including ball joints and all the steering parts, that add up.
I've had good experiences with Lares boxes, but most of it is dated some. One thing I'd do is get twice as much power steering fluid as I think I'm gonna need and purge the steering box, to make sure as much junk as possible is out of there. Not purging the box used to void the warranty.
