2000 Jeep Cherokee Sport
Under Hood
4.0L Motor
Fastman 62mm throttle body
Flowmaster Muffler w/hi-flow Cat
AEM Dryflow filter on custom intake tube
Optima Red Top battery
Viair 450 Air Compressor on custom bracket
AW-4 Tranny with Shift Kit
231 T-Case w/32 spline shaft
Tom Wood’s Custom Driveshafts SYE
Woody’s Front/Rear HD Driveshafts
Drivetrain
HP D30 with ARB air locker-30 spline
30 spline Alloy USA axle shafts
Alloy USA tube seals
Rotated and gusseted housing inner C’s
T&T Customs weld-on Truss
Custom LCA Skids
Custom Upper and Lower shock mounts
Custom Trackbar w/JKS axle bracket
Custom trackbar truss/crossmember
Ruffstuff HD diff cover
WJ brake swap with Akebono calipers
Custom 1.25” DOM steering linkage w/Tera TRE’s
Currie Anti-Rock sway bar with custom brackets
Prothane coil insert bumpstops
SS Long-travel brake lines
XJ D44 Rear with ARB air locker-33 spline
33 spline Alloy USA axle shafts
4:88 gearing
TJ Rear Disc brakes
Ruffstuff HD cover
Extended Bumpstops
Raised shock mounts
1.25” Billet Wheel Adapters
285/75/16 Maxxis Bighorn tires mounted on Jeep Moab wheels
Suspension and Chassis
T & T Customs Y-Link Arms and Crossmember
RE 5.5” Coils with .75 poly spacer
RE 1463 Leaf packs 3.5”
2” Custom anti-wrap spring perches
1” Custom boomerang shackle
Bilstein 5165 Front / 5150 Rear Shocks
T&T Customs weld-on Unibody Stiffeners
Temper Mental Racing reinforcement plates
JKS SBS plating-both sides
Armor
Custom Tube Front Bumper-1.5” DOM
Custom Rock Sliders 1.5” DOM
Custom 1.75" DOM Tube rear bumper -in progress
JCR Rear Qtr Guards-in progress
Miscellaneous
Bushwacker Flat Flares-painted to match body
Hella H4 headlights w/upgraded harness
Front Door storage pockets
Custom rear passenger seat headrests (ZJ)
Custom ARB plumbing with manual pneumatic switches
2 Gal Air storage tank
Uniden CB w/ Wilson 1000 roof mt. antenna
Fire ext , 1st Aid kit
Recovery straps , clevis, tire plugs, HiLift jack, LoLift Jack
