XJLI
- Long Island, NY
XJEEPER
Wheeling with my son in American Fork Canyon, UT
2000 Jeep Cherokee Sport
Under Hood
4.0L Motor
Fastman 62mm throttle body
Flowmaster Muffler w/hi-flow Cat
AEM Dryflow filter on custom intake tube
Optima Red Top battery
Viair 450 Air Compressor on custom bracket
AW-4 Tranny with Shift Kit
231 T-Case w/32 spline shaft
Tom Wood’s Custom Driveshafts SYE
Woody’s Front/Rear HD Driveshafts
Drivetrain
HP D30 with ARB air locker-30 spline
30 spline Alloy USA axle shafts
Alloy USA tube seals
Rotated and gusseted housing inner C’s
T&T Customs weld-on Truss
Custom LCA Skids
Custom Upper and Lower shock mounts
Custom Trackbar w/JKS axle bracket
Custom trackbar truss/crossmember
Ruffstuff HD diff cover
WJ brake swap with Akebono calipers
Custom 1.25” DOM steering linkage w/Tera TRE’s
Currie Anti-Rock sway bar with custom brackets
Prothane coil insert bumpstops
SS Long-travel brake lines
XJ D44 Rear with ARB air locker-33 spline
33 spline Alloy USA axle shafts
4:88 gearing
TJ Rear Disc brakes
Ruffstuff HD cover
Extended Bumpstops
Raised shock mounts
1.25” Billet Wheel Adapters
285/75/16 Maxxis Bighorn tires mounted on Jeep Moab wheels
Suspension and Chassis
T & T Customs Y-Link Arms and Crossmember
RE 5.5” Coils with .75 poly spacer
RE 1463 Leaf packs 3.5”
2” Custom anti-wrap spring perches
1” Custom boomerang shackle
Bilstein 5165 Front / 5150 Rear Shocks
T&T Customs weld-on Unibody Stiffeners
Temper Mental Racing reinforcement plates
JKS SBS plating-both sides
Armor
Custom Tube Front Bumper-1.5” DOM
Custom Rock Sliders 1.5” DOM
Custom 1.75" DOM Tube rear bumper -in progress
JCR Rear Qtr Guards-in progress
Miscellaneous
Bushwacker Flat Flares-painted to match body
Hella H4 headlights w/upgraded harness
Front Door storage pockets
Custom rear passenger seat headrests (ZJ)
Custom ARB plumbing with manual pneumatic switches
2 Gal Air storage tank
Uniden CB w/ Wilson 1000 roof mt. antenna
Fire ext , 1st Aid kit
Recovery straps , clevis, tire plugs, HiLift jack, LoLift Jack
mako my day
99 xj with a 90 front clip
D30/8.25 with HD diff covers.
4:56 with Yukon grizzly locker
Currie upper adjustable arms, RE fixed lowers, Drop Brackets.
4.5" springs and 1.5" spacers, 3.5 RE leafs with boomerang shackles
32" Muds on stock wheels with 1" wheel spacers.
Skid Row engine, tranny, transfer case, tank slid plates
JCR sliders that are bent and beat to hell.
Led rock lights.
Roof rack with shovel, axe, pick, bottle opener, high lift and 5 Hellas.
Dirtbound front winch bumper with Rugged Ridge winch.
Dirtbound rear bumper
foxwar71
1999 XJ
-Stock 4.0/AW4
-Stak 3spd monster box (1:1, 3:1, 5.44:1)
-Triple sticks
-Cut/sleeved XJ driveshafts
Front axle
-Narrowed late 80's HP60
-5.38's/lockrite
-Ten Factory shafts
-RuffStuff cover
-3x6x5/16 truss, Clayton coils buckets notched in
-Inner C gussets and heavily modded/plated ford knuckles
-NWF high steer arms and 7/8" heim steering/trackbar
Rear axle
-88+ C&C 14b
-Super shave job and turned 5.38 ring gear
-Orb of Traction
-RuffStuff disk brackets/shaved cover/pinion guard
Front suspension
-Mid-arm 3 link with Ballistic joints all around, 2.25" x .375" DOM lowers
-12" short body 7100's 360/80
-3" Prefender air bumps
-T&J-style upper shock mounts
-Engine cage to support shocks and bumps, ties into engine mounts too
-PSC hydro assist setup with remote resi and cooler
Rear suspension
-RE 3.5 leafs with 2 bottom leafs removed, 1.5" Teraflex shackles, relocated mounts
-Adjustable UBE's and front hanger
-12" 7100's 275/78 on hoops thru the floor
-Poly comp bumps
-Monster-sized RuffStuff traction bar
Tires/wheels
-17x9 black steelies with 3.5" backspacing
-DIYbeadlock flipoff smiley rock rings
-InnerAirLocks beadlocks
-37" stickie Maxxis Trepadors
Misc
-Full 3/16 frame plating
-Full hybrid cage and chopped rear roof
-Dove nose with more tube up front
-Dove tail with tube and skins
-THE Kastein's old MJ tailgate chopped up to it the tube
-No more useless wiring
-Tucked bellypan and crossmembers
-Raised 2x6 rockers
-1/2" thick plastic skid on the belly and boatsides
-Superwinch 8500 behind front crossmember
-Raised gas tank
-Half doors with built-in cupholder
-Brown Dog rubber motor mounts and super block brackets courtesy of the NACfest 11' and NACfest 12' raffles
-Cowl intake
Coming soon
-Cruisin' USA arcade game shifter wired for full AW4 control
-An instrument cluster that works
-Spool front and ARB for the 14b
souske
CA smog legal 87/96 hybrid
Chp 9" front, ctms, grizzly
Trussed 8.8 rear, arb
241or
Cage, ragtop, stiffeners
35" mtr-k
Warn 8274
Under Hood
4.0L Motor
Drivetrain
Custom LCA Skids
4:88 gearing
TJ Rear Disc brakes
Ruffstuff HD cover
Extended Bumpstops
Raised shock mounts
Armor
Miscellaneous
mako my day
Led rock lights.
foxwar71
1999 XJ
-Stock 4.0/AW4
-Triple sticks
Front axle
-5.38's/lockrite
-Ten Factory shafts
-RuffStuff cover
Rear axle
-88+ C&C 14b
-Orb of Traction
Front suspension
Rear suspension
-Poly comp bumps
Tires/wheels
Misc
-Raised 2x6 rockers
-Raised gas tank
-Cowl intake
Coming soon
souske
241or
35" mtr-k
Warn 8274
