W Wikkid98xj NAXJA Forum User Location NJ Apr 10, 2021 #1 Does anyone know the pn. For the johnny joint upgrade for the d30 axle mount bushings Sent from my SM-G986U using Tapatalk
Phil NAXJA Member NAXJA Member Location West Sacramento, CA Apr 10, 2021 #2 https://www.google.com/search?q=currie+dana+30+johnny+joint&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
W Wikkid98xj NAXJA Forum User Location NJ Apr 11, 2021 #3 Phil said: https://www.google.com/search?q=currie+dana+30+johnny+joint&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari Click to expand... Do these fit both sides? Sent from my SM-G986U using Tapatalk
R RCP Phx NAXJA Forum User Location Phoenix,Az Apr 11, 2021 #4 This one is the stock replacement........ https://www.morris4x4center.com/currie-enterprises-machined-johnny-joint-kit-with-7-16-bolt-fits-housing-casting.html?gclid=Cj0KCQjwmcWDBhCOARIsALgJ2QdUAxMumNxyFMO2gNZ9xKEo26D9HOyn639xwPM_cxCg4Gpt4NtYBFAaArnIEALw_wcB
GordoSmasho Nevada Raisins NAXJA Member Location Virginia City, NV Apr 11, 2021 #5 Ive used these a few times as well. They work well. They also have a 1/2” bolt version. https://www.ironrockoffroad.com/product/upper-control-arm-flex-joint-8-bolt-10mm-cartridge.html Last edited: Apr 11, 2021
Phil NAXJA Member NAXJA Member Location West Sacramento, CA Apr 12, 2021 #6 Careful you don’t tear off the passenger side upper control arm mount from the axle if you use all hard joints.
Anak Stranger NAXJA Member Location In a strange land Apr 12, 2021 #7 Phil said: Careful you don’t tear off the passenger side upper control arm mount from the axle if you use all hard joints. Click to expand... That is a very good point. And probably the reason there is a kit for these that includes a solid steel insert for the passenger side, intended to be welded to the axle tube.
need-a-bow NAXJA Member NAXJA Member Location Illinois Apr 12, 2021 #8 GordoSmasho said: Ive used these a few times as well. They work well. They also have a 1/2” bolt version. https://www.ironrockoffroad.com/product/upper-control-arm-flex-joint-8-bolt-10mm-cartridge.html Click to expand... The IRO joints are great, I know plenty of people running em. I actually have a press in style one I could sell cheaper, I need a weld on version for my new swap so it's just collecting dust Sent from my Pixel 3a using Tapatalk
