Chill-X
- Tucson, AZ
[SIZE=+1]Shocks & Accessories[/SIZE] (all New/Open Box - all parts/hardware/instructions/open box included):
Pricing/Shipping:
Prices are negotiable, however I am trying to get as much as I can. Currently, I have been unemployed for many months and an running a bit short in funds. Consequently, I will be able to ship out very quickly unless I manage to get an interview somewhere or start a job (I am an Accountant with 3 years experience and excellent academic credentials). Shipping will be via FedEx Ground, UPS Ground, or US Mail (whatever is easiest for me).
Local Pickup/Delivery:
Everything is available for local pickup (near Broadway & Kolb in Tucson, AZ) and available to check out if you want to see first. I will also be able to bring anything smaller than an axle to you in the Tucson area. I have no way to transport an axle on my own so that will be pick-up or ship on a pallet only.
Axle shipping:
I actually have a large (extra-long) pallet that I can strap an axle onto (suspension pieces may be unbolted and tied/boxed separately if purchased with axle). So yes, I can ship the axle to someone. Freight would be pick-up by trucker in driveway.
Everything is available for local pickup (near Broadway & Kolb in Tucson, AZ) and available to check out if you want to see first. I will also be able to bring anything smaller than an axle to you in the Tucson area. I have no way to transport the axles on my own so those are pick-up or ship on a pallet only. I'll knock a few $$ off shipped prices if you pick up.
Payment:
Money Order or cash is always nice. I will also take PayPal (including credit cards) for shipping or local pickup.
References:
I was a big computer nut (still am a bit). I have bought & sold many computer parts on forums in the past as Chill-X and have a Heatware Account. I also have 124 verified buyers in PayPal and have been a verified member for in excess of 8 years. This is the first time for me selling Jeep parts though.
Contact:
If you want to buy, make an offer, ask questions or anything else, contact me by Private Message or email (this is the same as my PayPal email): jcdickey @ gmail .com - also feel free to post in the thread with questions if you want for the benefit of all. Thanks, Jason
Stuff I want:
0.75" or 1.25" aluminum spacers from the JKS Adjustable bumpstop system (have leftovers?), smallish automotive fire extinguisher, 3/4" D-ring shackles, tree saver, 1/2" keyed chuck drill with screw-in style side handle, ammo cans
- Old Man Emu N39L (pair), $80 shipped
N39L is an upper stud, lower eye style shock. My measurement is about 15.25" fully compressed length, 26.5" extended - Old Man Emu N40L (pair), $80 shipped
N40L is an eye-to-eye style shock. My measurement is about 15.5" fully compressed length, 26.5" extended - JKS 9601 XJ Front Upper Shock Conversion (pair), $28 shipped
- JKS 9603 Front Lower Bar Pin Eliminator (pair), $38 shipped
- JKS 9604 Rear Upper Bar Pin Eliminator (pair), $40 shipped
- Rubicon Express RE2500 Drop Pitman Arm for Wrangler/Cherokee (new in sealed plastic package). $35 shipped
- JCR Offroad XJ Rear Bumper Unibody tie-in bracket (pair) (came with their bumper but I built my own, includes bolts). $15 shipped
- Hi-Lift Bumper Lift BL-250, new sealed package. $14 shipped
- Central Machinery (Harbor Freight) 12 ton Jack Stands #34924 - adjusts from 19.5" to 30.125" tall - never really used but left outside in sun (faded orange paint). $20 local
- Lightly used stock spare tire and wheel for 2001-2003 Toyota Prius, may also fit 1997-2000 Prius (4 lug pattern). $20 local
- Spare tire mounting hardware & floor bracket (behind rear seat) including hand-tighten lug nut thing - $4 + shipping
- Emergency bottle jack/handle/lug nut tool - $8 + shipping
- Transmission Crossmember - no built-in drop, in good shape (not dented) - $8 + shipping
- Bumpers:
- Front Bumper side plastic pieces - faded, one side has crease in the plastic from being hit
- Front Bumper mounting brackets - should have bolts as well
- Front Bumper license plate plastic mount
- Front Bumper lower plastic deflector
- Rear Bumper mounting brackets - probably have bolts as well
- Rear Bumper to body/tailgate plastic piece
- Front & Rear metal bumpers Desert Sand Pearl Coat - both have been bent/bumped/smacked around
Looking for $20 local pickup for all the bumper stuff. I may also be willing to part with the rear bumper endcaps/lower quarter guards (whole), and possibly all 4 fender flares (for more $$)
- Wheels: Qty. 4 - 15x7" aluminum wheels, 5 on 4.5" lug pattern - 5 wide spoke design, color matched to body (Desert Sand Pearl Coat), has center caps, includes worn-out 225/75R15 tires - $85 local (wheels look like this: http://www.naxja.org/forum/attachment.php?attachmentid=881)
- Dana 44 stock (thin) cover - has hole drilled by junkyard which was welded closed - $free local
- Dana 44 drum brakes (from an '87) - big brakes includes e-brake cables - these use 10" diameter x 2.5" wide shoes (as opposed to the 9" dia x 2" wide in the Chrysler 8.25" axle) - these will need to be cleaned & rapaired - new cylinder, possibly new shoes, resurface drum (I understand that these could be put on other axles for a brake upgrade), will include Dana 44 drum brake hardlines - $20 local
- Rear Suspension (from a '99 Chrysler 8.25"):
- stock leaf springs
- axle u-bolts and plates
- Stock shackles (no bolts)
- Stock skinny anti-swaybar - has axle-end hardware but missing frame-side mounting brackets/bushings
- Have stock shocks (need replacing) if you want??
- '99 4.0L/AW4/NP231/C8.25" stock rear driveshaft - has scaly-rust on tube
Looking for $15 local for both stock leaf springs, another $5 for the u-bolts, plates and shackles, everything else free
- Dana 30 working pull (from a '99 with 70K miles), 3.55 gears, open diff, standard cover, disc brakes (includes stock rubber brake lines)
fairly clean/relatively rust free, except brake calipers and rotors
- Upper and lower control arms including stock nuts and bolts at both ends, also includes LCA adjusters
- Coil springs good shape including lower retainer clip & bolt in spring perch
- Coil spring rubber isolators (upper) & bumpstops
- Swaybar end-links - includes hardware except it is missing 2 of 4 upper-end washers (swaybar not included)
Hoping to get $120 for the axle & brakes, $150 for axle, brakes, UCA & LCA, springs, swaybar end-links - prices are local pickup, can ship this on a pallet at your expense
- Trackbar including bracket (very good shape) - does not include axle-end or frame-end nuts or bolts - $50 shipped
- Stock steering linkage (all pieces of linkage are there but probably needs new boots and reassembly) including stabilizer with axle-end nut/bolt - $40 shipped
- Aluminum steering box spacer (intact)
- have stock bolts for steering box as well
$5 + shipping
Pricing/Shipping:
Axle shipping:
Payment:
References:
Contact:
Stuff I want:
