MATTVW65
- Layton Utah
this is a short list. if there is something I have that you might need or are looking for call or text me at 801-725-0112.
make offer on anything
Matt
00 engine $900 complete 134k still in jeep if you would like to hear it run
00 aw4 trans $200
00 242 transfer case $200
dana 30 355 gears $200
8.25 rear axle limited slip 3.55 gears $200
1997 4.0 engine compleate $700 120k in good running condition
radiator's $40 ea
235/75r 15 tires set of 4 on jeep rims $300
Rubicon express upper rear control arms super flex adjustable zj or tj $100
tearaflex adjustable lower control arms
xj tj or zj $100
skyjacker fixed lower control arms $40
skyjacker adj track bar $50 from the rockready 6"kit has frame end bracket included
rear overhead speaker tray $50
teraflex 2" lift shackles $50
rocky road 2" lift shackles $50
skyjacker extreme drop pitman arm $100
Rubicon express drop pitman arm $40
skyjacker bump stop set $10
transfer case drop kit $10
full s.s.t custom built sway bar disconnect set $75 for 5" to 8" lift
jks bar pin eliminator set $20
rear lift blocks 3" $15
alum 2" $10
steel 3" $20
99 aw4 transmission $100 auto
ft drive line $ 40
rear drive line $30
starter $ 25
rear hatch $50 white 99
steering gear box $40
dash cluster 97+ $50
ft drive lines $40 each
1994 Dana 30 axle 3.07 gears $200
1993 Dana 30 axle 3.55 gears $200
1998 Dana 30 axle 3.55 gears $200
1998 Dana 35 axle 3.55 gears $200
1999 Dana 30 axle 3.55 gears $200
1999 8.25 axle 3.55 gears $200
jeep Cherokee rear Dana 44 $450
jeep Comanche rear Dana 44 $450
cross over steering arms $40 Chev flat top
ft 2000 xj drivers side seat $100
rear 2000 seat $40
1997 xj front seat drivers $100
passenger $50
matt:wave:
text is best
801-725-0112
Matt
00 aw4 trans $200
radiator's $40 ea
xj tj or zj $100
alum 2" $10
steel 3" $20
ft drive line $ 40
rear drive line $30
starter $ 25
rear 2000 seat $40
passenger $50
matt:wave:
text is best
801-725-0112
