JBL amp and speakers
tcm glx
NAXJA Member #1033
pair of 6 1/2" JBL Speakers Model Number GT6.0C
JBL 4 Channel Amp, model GTQ 190
Specifications:
No. of Channels 4 Channels Bridgeable
Power Output 40Watts RMS per channel, 190Watts RMS Bridged 4 ohms
Load 4 and 2 ohms
THD 0.05% max.
Signal to Noise Ratio -100db
Bandwidth 20Hz-50Khz
Special Features:
Built in Amplifier Crossover HP and LP=100Hz selector
Built RCA Output Crossover HP and LP 100 Hz selector
Preamp Output Switch selector IN/Out Signal
Short Circuit protection 150 watts trigger sensor
DC Offset Protection Sensitivity 1.5Volts DC sensors
Automatic turn ON Sense Speaker input signals
Speaker Inputs Sensitivity 1V to 4 volts
RCA input Sensitivity 0.1 to 1v 0.5 nominal
Remote ON/OFF Antenna Input level
Topology Class A/B
100 bucks for amp and speakers!!!
Bump, will split up speakers and amp.... want this stuff gone!
Do they come with the crossovers and the tweeters? If you got those I just might want them.
No crossovers.... but the amp can cross them. No tweeters.... its an amp and some awesome mids though!! Come on!
