is this worth a damn? CL ad
i wish i could give you a educated response. but i cant.. my GUESS is that its not really worth it because it looks like the diff is off-centered to the right?
It looks like they made it themselves. Look at the tubing towards the left.
I have a HP44/9" rear out of a bronco that i will sell you for $400.00. I got them to put in my jeep, but some things have come up and I could really use the cash instead. The front has the weld on wedges which means it would be perfect to swap into an XJ.
It depends on what you want to do with the D44's.
You'd probably be much further along getting a Ford 8.8 from a 95+ Explorer for the rear though.
The front would only be useful to you if you were planning to swap your transfer case with something like a Dana 300 because it is a passenger side differential.
X2E's offer is a better deal at the end of the day.
