Is this chain shot?
Cottontail
Three-De Off-Road
Nashville, TN
Not sure if it is bad or just loose because everything is open. It's not hitting the bottom of the case, but I did find lots of metal on the magnet.
Its hard to tell with the main shaft hanging loose, you have to push the main shaft up a little and then look at the chain. Also look at the bottom of the transfer case for ANY kind of scratch damage. I have seen some that were scalloped out, can't see anything like that on yours but the chain is blocking the spot.
As it sits in the pic, I would replace it
Yeah, for $70 and support of one of NAXJA's vendors, it made sense just to go with new before I buttoned it all back up. The bottom of the case has no damage, so I don't think the chain is that bad, but $70 is cheap insurance.
If you take it off and hold it sideways you can see how much it droops (like you would check a timing chain). That will tell you if it needs replaced.
They also make great blackjacks...
Good call to replace since it was open. That being said I hope that's wasn't the sole reason for opening the case unless you had other issues. I replaced mine in the 242 I had because it was skipping teeth in 4lo. Very stretched.
No...I'm also doing a full case SYE.
$70 seems steep for a chain, I bought a Morse last year for about $40? But as ehall indicated the mainshaft tends to hang down and to the left when its not supported... I compared the new chain to the one in my 242 and when I realized there was no stretch I sold the new chain to a forum member.
Well, better safe than sorry.
