DansGreyMj
- Nuevo, Ca
It will not make any pressure. It will only reduce the work the engine does to pull the air into the cylinder. It would make a difference but a negligible one. It could, in fact be argued that the electrical draw would negate any benefit.jeannies_driver said:let's see,
the average hyped up hair dryer run's at 200 CFM's
a 4.0 liter engine is 244 cubic inch's or 0.14 cu. ft.
244cu.in. x 3000 rpm's = 732,000 cu.in/minute or 420 CFM's
divided by 2 ( 4 stroke engine only has 2 crank rev's/4 stroke's )
make's 366,000 cu.in/minute or 210 CFM's.
technically off idle it help's but exactly how many lbs of boost it add's is the question. someone else can figure that one out.![]()
yes it's a gimmick,, tell us how it work's......
MudDawg said:It will add another 75 hp, but only if you also add a "tornado" and an inline fuel magnet, a set of battery chains to hold in the power and half a dozen "Type R" stickers. They also make a "Gen II" electric supercharger..those are double top secret...they are hidden inside the fake superchargers on NHRA Top Fuel cars....![]()
99XJeeper said:It would probably actually interfere with the air entering because the engine is pulling in air quicker than the "intake"
