Kreutz
- Chicago, IL
I've been having trouble with my jeep not wanting to run. It starts and then dies. It's only done this twice in the last two weeks. This morning being one of those times. I tried a new resistor and no change. I looked around a bit and made sure everything was connected. I found, what I think may be the EGR regulator, and it was not plugged in all the way. I plugged it in and still no change. I unplugged it and it started right up. It is located right next to the resistor., and it's the only thing that is in the same wiring harness as the resistor. There's a bit of corrosion inside the connector. Will it hurt anything to just leave it unplugged, whatever this may be? It's running better now then it has been for months. I've also been having a really bad surging problem. Could that have been the contributing to the cause? Any thoughts?
Thanks.
'90 xj
4.0L
Thanks.
'90 xj
4.0L
