Is the front drive shaft supposed to rotate when not in 4wd?
corbinxj
Williamsport, PA
I have read a lot of post regarding front drive line vibes and have come to the conclusion that it's probably drive line angle issue because I took the front shaft out last night and no vibes.
I just want to make sure it's not a shaft out of balance. I did an axle swap and since then vibes. Fixed the angle in the rear with shims and vibes disappeared.
I have adjustable LCA's so I should be able to fix the angle pretty easy.
Thanks in advance for your help!
If it's non disco axle, Yes. it will always turn while moving since it's connected to the wheels. It's just not connected in the TC.
Check your u-joints. How big is your lift?
You didn't give your year. It rotates on most years, but the earlier ones had vacuum disconnect and those won't rotate. The vacuum disconnect is a big can (4-5" diameter????) with a vacuum hose going to it that is on the axle on the drivers side IIRC.
it's on the right side, but yeah, otherwise correct. If you have vacuum lines leading to the right side of the front axle, you have a vac disconnect one and the shaft should not turn in 2WD.
His profile lists a 98. I saw this after my post.
Yes it's a 98 with 3" lift in the front and 4" in the rear and a TC drop of 1". I'm not sure of the year the swapped D30 is but it does not have any vac lines.
No vibes previous to the swap.
