B.RAIDER
- Central Texas
I repaired an ill fixed (by someone else) vacuum line to the Map sensor located on the firewall.
The plastic line had been broken at some point and a rubber line was slipped over it (connecting the two ends together). The inside diameter of the old rubber line was too big so I replaced it ( the rubber line) with a better fitting one.
Now I have an irratic idle from 750 to 1000 rpms.
Do I need to reset my TPS?
It was a simple fix....so I know I didn't disturb any of the other stuff in that general area...........:dunno:
