Inverted T steering
Israel
This came on a JK Dana 30 I thought I was going to use until I changed my mind and started to build a Dana 44.
The tie rod is 59" center of joint to center of joint, and the drag link is 37". One of the TRE's needs to be replaced. The boot is torn and it looks to be bent to me. I believe they are 1 ton Chevy tie rod ends, so super beefy.
Looking to get $150. Let me know if you have any quesitons.
This is the bad joint. I'm trying to show the part number so you can look up cost of a replacement.
