sardo_67
- western CT
well Picked up Ryans old jeep, heater worked on the ride home, few days later it did not. after messing with the wires my brother burned himself and we soon realized the wires to the blower motor were bad. there was a short somewhere and it had melted the rubber plug causing them to not contact the terminals so the motor would not spin. i added some wire, cleaned it up and then put blade connecters on the end which i attached to the motor.... it works!!
week later it stopped so i wiggled the wires and it worked again...
now, if the jeep is cold and i start it blower works in a 4 settings and very strong on 4. once it warms up it starts slowing down and eventually stops working altogether. i go under the hood and move the wires around it will work again but, once it does for a while it stops.
i'm guessing it's time for a new motor right? i have a new one in the jeep now i just need to put in once i get the correct wiring connecter.
what could be causing this?
