MrShaft696
- Blue Bell, PA
I scored a 29 spline 8.25 out of a 2001 automatic, I have a 96 with a 8.25 and i am not sure if its a 27 or 29 spline but it has 3.07 gears and I am using this rear mainly for the gearing since i run 31s and got it for 35bucks.
The one difference I noticed in the axles is the parking brake set up. The older jeeps the adjuster is right in the middle of the trans tunnel basically, and the 01 it is mounted to the frame rail. i took the entire assembly off the 01, will i be able to hook it up to my brake handle? Should I hook it up to the old stuff somehow? Anyone have any advice or other swapping issues i should be aware of before I give it a go.
