OnorOffroad
- Enterprise, Alabama
So I installed a 9" axle in my 95 today. Aside from the rear chassis side brake line busting, everything went smoothly. Except.... I don't have leaf spring center pins/bolts. The axle isn't staying centered fore/aft under the jeep. Are the leaf spring bolts the culprit?
Also, the rear axle is 4.88 gears and the front is 3.55. As long as it's not in 4wd is it safe to drive or should I disconnect the front driveshaft for now?
Thanks
Thanks
