Jimminyc
- GJ, Colorado
Im sure other people are running one tons and i wanted to find out what you did for a rear drive shaft. Ive got the AA SYE but im not sure i want to go with the CV joint in the rear for strength. I want to have the 14 bolt yoke on one end of the shaft, and the XJ yoke on the other. Im not sure if i should just stick with a front DS and change the rear yoke (I dont want to do the adapter U-joint--Expensive and hard to find in a pinch)
SO, what have you done? The DS shop will charge an arm and a leg to start from scratch. Has anyone else ditched the CV joint?
