XJosh95
- Green Bay, WI
The things we do to change oil...![]()
It's out
mac 'less than 3 hours' gyvr
It's out
Nice new stairwell going in...
Think it will hold? Some type of epoxy at the corners. No sign of weld.
you'd be surprised at the strength of some of the structural epoxies.
now, did they prep it properly before they glued it is the bigger question to ask....
Tell me about it. They used one while I was in the Air Force for attaching tethers for tools on the missile silo. Heat released them but otherwise a dab of the size of a half dollar would hold over 150lbs. after curing.
Starting Christmas lights today. Will not turn them on till after Christmas. Tired of deep snow and highs of <20 degrees to put up some damn lights. Would rather be working on my Jeep but awaiting parts from Advance.
I need some of that stuff. I could be spiderman.
fat guys need not apply![]()
^like
Will like the "its in" pic better.
No lights for us this year, even w/o the broken body we decided to skip. I took last years down in mid summer.
I also doubt that it matters. Again, with trying to be diplomatic, trust is a bit of an issue with the frequency of miscalculated compensation. I'd rather them be able to take a paper check back than tell me that I'm up sh!t creek because I've "already cashed" it with direct deposit. There could certainly be some legal dancing and hassle I could go through with that since I wouldn't be surprised if they pulled that on someone, but I'd just rather not go through the experience.Josh, if your employer is sketchy with payroll, I don't know that it matters if it's a paper check, or a direct deposit. The employer can tag a direct deposit transaction for pretty much any date they want. At least with a check, the date means relatively little, you should be able to present it for service at any time (subject to the stale check issue.) Personally, I haven't gotten a paper check for payroll since 1994.
Mac, didn't the reman engine come with a good oil pan?
I guess that I should count myself fortunate, I don't recall ever having a miscalculated paycheck (I've also spent a fair amount of time doing payroll system maintenance & development.) It's also been 25 years since I drew an hourly paycheck.I also doubt that it matters. Again, with trying to be diplomatic, trust is a bit of an issue with the frequency of miscalculated compensation. I'd rather them be able to take a paper check back than tell me that I'm up sh!t creek because I've "already cashed" it with direct deposit. There could certainly be some legal dancing and hassle I could go through with that since I wouldn't be surprised if they pulled that on someone, but I'd just rather not go through the experience.
XJosh 'trust 'em as far as I can throw 'em' 95
Front flares kept trying to fly off at speeds over 140mph. Decided it was time to move them up just a little. They ended up moving 1.5 inches up and a huge amount of fender ended up coming off.
BEFORE:
DURING, from the passenger side:
FINISHED:
Clearance behind the front tires is much better than the picture portrays
Thanks to Flex for bringing Dr Pepper.
Driveway wrench-fest completed... Fender relocation / Flex's Tire Rotation / Two motor mounts on Flex's rig.
That's all, Thanks.
Really? Why not BEFORE Christmas??
Rev
Big Stank and I had a mini wrenchfest today. He relocated his front flares and rotated my tires. Then we noticed that one of the hoses under my hood had been touching the hood. Thats when we found this:
Good thing i won those motor mounts at the trail clean up! Thanks Brown Dog!
That's all, Thanks.
Atleast you got it before you ate your radiator
-Ron
Flap wheel and black spray paint!BS post, XJ's won't do 140mph downhill with a hurricane trail wind
Looks nice. Did you sand and seal the cut edges to prevent rust? If so, what did you use?
-Ron
