I'm 12, and what is this?
Swamprat
little Tijuana
Ok, I'm not really 12. but i am not sure what this is. i've never seen a pinion brake looking thing on any XJ. it looks factory, and i dont think it works at the moment.
i'm stumped...
-Ian
What the hell is that?
well there is a pad of sorts, and it touches that "ring" at the very front. thats where i got the brake park from. i dont know what it is, but it'll work as a pinion guard lol
Looks to me like a rear axle disconnect although why you'd need that ... dunno.
I'd be all over finding where that cable leads and then figuring from there.
EDIT - found it ... Remco disconnect
http://www.remcodsc.com/
as foxwar71 stated ... for towing behind your RV
Thats kind of neat. But, kind of not needed for towing an XJ. Just put the transfer case in neutral, transmission in park and roll. I guess if you wanted to save wear on the transfer case.
Do you have an extra lever someplace for it?
Unless its an old XJ with a vacuum disconnect on the axle. The tcase didn't have a true neutral and if you put them in neutral while it was running it would lock the front axle in and blow up the tcase.
It happened to me.
