Alexia
- Huntsville, AL
1997+ ignition cylinders
The ignition lock cylinder will not slide into place. I took it out to replace it with a good one. The key is in the run position so the lock tab will depress when going in, but it gets stuck about half way into the switch. I even wiggled the key and pounded it a bit. Just will not go back into place! The switch is also in the matching On position. Any idea or something I am missing?
I even tried disconnecting the ignition interlock cable in case it was interfering somehow.
