Idle Air Solenoid Help
BuGG
Ok my IAS is bad. I have it disconnected but since its cold here now I am getting bad cold Idle. When it warms up its fine but cold its very low. So I need to buy one now. I just got back from the dealer and they want $137 for it and a week to get it. That can't be the best price. I remember checking www.carparts.com in the past but couldn't find it. Is this a dealer only part? Where is everyone else getting there's?
Thanks
BuGG
Did you check Napa?
By IAS you mean Idle Air Control Motor?
Stepper motor...idle air control motor...same difference I believe.
I just bought my IAC yesterday at Napa for $78CDN (60USD).
HTH
I was just browsing Autozones website. They have a Idle air control vavle for $65 a Wells PN#AC301 Is that it?
BuGG
Autozone
I got the Wells brand at Autozone for about $60 also and it solved my problem. Before you spring for it I would suggest pulling it and cleaning it and the throttle body hole. Be careful not to lose the rubber o-ring. This helped some and seemed to solve the racing idle for about a year. Eventually I had to replace it- but you may be lucky.
Yeah I have cleaned it several times and it comes back. Its very old and since I have pretty much everything else new except a fuel pump and regulator I might as well get this. Thanks for all your help.
BuGG
Rockauto.com will have it on your doorstep by the end of the week if you order it today. They generally sell quality products.
