nader89
- north carolina
okay friends i just purchased a 94 xj 4.0 ho auto with an aw4 trans. here are my issues and if anyone has any input it is all welcome cause idk where to go from where im at now... okay so the trans is not shifting right when i put it in drive it takes off and gets up to about 4000 rpm then shifts then i gotta feather in and out of the throttle to get to the next gear. i unplugged the tcm and i can shift it manually great just dont have second so i know the trans is mechanically sound must be electrical. so any thoughts on the trans issue? maybe tps or solenoids?
next is today i had it in the shop and i recharged the a/c and its working good but i drove it home with the a/c on and it sat outside for about a hour and a half and now it wont start? any ideas on what that could be? i can lay under the truck and hear the fuel pump kick on for just a couple seconds like it should and i have fuel in the rail at the pressure release so maybe cps? any ideas or guides would be great thanks. i have had the heat bath problem also after it sits about 15 mins after driving it cuts a buck when you start it back up for a min or two but then smooths out and runs great.
thanks
naxja friends!!!
thanks
naxja friends!!!
