I have bearings separate if needed. As well as the correct shims for that elocker.
I also have one setup bearing, only one because with the correct tools only one is needed, the side with the actuator.
Let me know if you need a set of bearings to make setups out of (just use a barrel sanding bit on a die grinder) and some shims...
Or if you want to sell that failure prone E-Locker that most wont run due to known issues, I can get you setup with a great air locker that comes with brearings, shims and all the shims are on the outside of the bearings, so its a much easier install
just saying
