Ok, I have a 95 with the aw4 .If i get on the throttle when going down the road to speed up and get on it a little It will Jump to about 3-4 rpms that is the only time it will do it.I was told by a tranny shp to replace the fuel filter so i replaced it helped out a little bit. when it dose this it dose not slip it just takes off when i go to gradually build speed . I cant figure it out is it a sensor I dont wanna put a tranny in and it not be the problem . If I take it easy will not do it at all.
Thanks alot for your time
95sport
95sport
