I am going up to Holcomb this Sunday but i need some new brake lines for a 6-7" ish lift!!! PLEASE text me if your near long beach and you have some! Thanks a lot!!!! (562) 387 9286
Dodge RAM 3500 lines, and some others you can get from a parts store work. There is a thread somewhere around with part numbers. You could also probably PM grimmJeeper and he could give you NAPA PNs
98 dodge dakota rear center line at kraken auto. $16. bolted right on. Perfect for my 6" lift.
Front, just unbolt the hard lines and bend them straight down.(temp fix........perm for me)
front lines use 98 chevy 1500 2wd hoses. should run you about 33 bucks for the pair.
I have a set of steel braided hoses I had made but they are probably too long for what you need, I was on 8" of lift. they are 27" long, $60 for the pair. less than 1000 miles on them, broke the jeep and parted it out. located in Gardena (end of the 91 west).
I got 96 Chevy c1500 lines form orielly but haven't put them on yet. at first they look like the banjo fitting is smaller then the cherokee, but i haven't taken apart the cherokee one yet so idk we'll see. And thanks Grim, ill do a flex test once my new lines are in and if i still out flex them ill buy the braided ones for ya!!
