- Charlotte NC
So I found out I have leaks...not on my person but my '92 XJ!
The front diff. cover is leaking (apparently when you slam rocks constantly it takes a toll). Any tips or tricks when I go to put a new gasket in I should do? (not how to do it, just any upgrades or things of that matter I can easily do) It's a stock D30.
Rear tail shaft seal is leaking...any opinions when I change that?
AND I sort of have a mytery leak...Here's the story. The motor is a 4.0L HO out of a '98 ZJ (vision it).........I changed the power steering box because it was leaking like a civ. So at that point I don't know if I already had this particular leak.
Alright if your on the drivers side looking down the front of the motor, it looks like there is a leak from the left side on the bottom of the water pump near the exit to the lower rad. hose. It is leaking from there down the center of the oil pan and onto the ground however it does not seem to be coolant. There are a lot of lines sitting right there for the trans cooler and crap...but the fluid looks like power steering fluid....I have not investigated it any further, but I will tomorrow....My question is to you all is...Is there any common leak right in that area of the engine compartment and if so how much of a pain is that "common problem" to take care of?
thanks again guys
thanks again guys
