Cottontail
Three-De Off-Road
- Nashville, TN
Ok - first the specs:
The front axle shafts, both of them, had brand new 760 u-joints installed just before the Cherokee Crawl in July. The front drive shaft has all brand new joints. Again, installed in July.
I have pulled the front diff cover to check the locker and check the axle shaft seating in the gears and I see nothing out of place or visibly out of alignment. The fluid was free of metal flakes.
I did notice last time that I was in 4x that I had some noise from the front axle which was what lead me to check the axle guts in the first place. It sounded more like two pieces of sandpaper rubbing against each other than it did metal on metal or clunking or anything else.
So, today I took a little drive down the interstate with the driveshaft off and the vibration and noises were gone. That leads me to wonder:
(a) is there an issue inside the axle that is getting magnified with the drive shaft on
(b) is the driveshaft out of round
(c) is the axle off center and that noise/feeling is due to binding
(d) all of the above
(e) none of the above
I'd like to hear some thoughts, if you have them.
- 2001 model year
- 3.5" lift kit with 2" spacer/shackles for 5.5" total
- HP D30 front with 4.10 and Aussie locker
- Fixed aftermarket lowers, OEM uppers
- Drop brackets
- Adjustable trackbar with double shear bracket
- OEM brake set up
- 265/75/16 MTs
- Not running a steering stabilizer or a sway bar
- ZJ solid tie rod
- Checked before my 500 mile road trip last week to be sure all bolts and nuts on the front were tight. They were.
