I don't usually pound studs into anything. I turn a lug nut around backwards and tighten it to pull the stud in. The front studs have an unthreaded portion, you may need a stack of washers (as spacers) to seat it all the way.
I don't think there are any clearance issues? The stud should go in from the back, best to double check though.
