hub bolts
shawnxj
portland, tx
ok so i disassembled my entire front diff and managed to trash the bolts holding my hubs to the knuckles. so where do i get new bolts from? or should i just go buy some grade 8 bolts?
So what did you end up doing?
M8-1.25 socket heads, match the length under the head. Hardened flat washers might not hurt - you can use 5/16" hardened washers if you can't find them in M8 (they're close enough to the same size it really doesn't matter.)
Hex head capscrews should be at least Property Class 10.9 for that application.
