Prepmech
NAXJA Member #981
- Neoga/Decatur, IL
HPI Savage 25 Nitro RC Truck
$350.00
I've spent over $1000 on this truck. It has had less than 1/2 gallon of fuel run through it. Broken in properly, used after-run oil. Includes everything needed to run except for Nitro fuel. Original engine and 2 speed transmission.
Many hop-ups:
Reverse
Dual disc brakes
High flow air filter
Fail-safe (hits brakes when out of range of remote)
Clamp on wheel hubs
Larger wheels/tires
Stainless steel hardware kit (not installed)
Upgraded throttle/brake linkage
Boost bottle (not installed)
New rollbar (not installed)
All parts needed to convert to 4 spider gears in both diffs (not installed)
New toyota land cruiser body (never installed or painted, not shown in pics)
Lots of tools
Rotostart
All necessary batteries and chargers
IR Thermometer
Engine and Chassis manuals
Shock oils, diff oils, after-run oil
Charged up the hump pack and checked all servos, steering servo is working intermittantly. May be a bad connection, new servos are not very expensive.
$350.00
Many hop-ups:
Reverse
Dual disc brakes
Clamp on wheel hubs
Larger wheels/tires
Lots of tools
Rotostart
IR Thermometer
