assuming the ABS systems are interchangeable (?) 1992 - 1999.
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 1984-1999 (some axles through 1991 are vacuum disconnect), 1992+ are non-disconnect, 1989-1999 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints.
