How to remove powder coat
RichP
Effort, Pa
Just got a slightly dinged up front diff guard for my D30, want to clean it up and repaint it, whats the best way to get powder coat off ?? sand blast, pour gasoline or kero on it and set it on fire, put it on an old propane grill and cook it for an hour or two, go after it with a propane torch, hang it from tree and go at it with #6 shot reloads and a 20ga or 7 1/2 with the 12ga ??
I like the gun approach. 000 shot would work best.
Try aircraft stripper. Otherwise I would just use a grinder and go to town.
The best method I found was when I was stripping down Led's bead lock rings for re-painting.I used aircraft stripper first then what was left I finished up in my blast cabinet.Hope this helps.
Jeff
Glad to see you got it, I hope you're not too displeased with its condition.
Ary
