How to install Add-a-leafs?
get new UBolts and spring Clamps. Search for a write up. Quick and dirtyis, C-Clamp springs together drop axel down, leaving springs in rig, cut spring clamps realease c-clamps slide the AAl in, re clamp with C-Clamp, re attach axel, install new spring clamps, remove c-clamps, your done.
You'll need (or want) new center pins as well - get really long ones or use a piece of steel rod to keep the holes all lined up while you reclamp with the C-clamps (get the 6" really strong ones, not the little ones). Don't use the center pin to clamp, you'll wear on the threads a lot more and it's not as easy. You got OME leafs as I recall, so you can probably just undo the bolts on the leaf clamps rather than cutting them off.
