dellstopjeep
- KUNA, ID
I have the 3 inch lift but i want to go bigger without changine my setup. I have a clean 3 inches in the front and AAL in the back, which sagged about a half inch in a couple weeks. I put a 1 inch block in the back to even it out, so i technically dont know what the rear lift is. But i want a little more tire clearance and just a rig that site a little higher. I know about coil spacers and shackles But where is my limit before i got to A) Extend brake lines B) Driveshaft C) SYE D) transfer case drop. To get the added height i am willing to purchase a transfer case and brake lines becasue they are cheaper then the other two. And if i used shackles in the back should i just remove the block. Can i get to 4.5 inches before doing anything. Unfortunaly i got rancho 5000's so i think i will have to replace those to but o well, i made the mistake of not getting the 9000's. Advice would be appreciated. thanks
