bpatto10
- knoxville, tn
Hello,
1996 Jeep XJ, 231J transfer case, 8.25 rear axle, While testing various things in search of a whine noise, I noticed a little slop up and down in my transfer case rear output shaft. It feels like maybe 1/16", hard to tell exactly. I don't feel any slop while pushing the shaft in or out. I have seen several threads about rear output shaft bearings going bad (and even snap rings breaking). Some of these threads have indicated there should be no movement at all. I checked the transfer case fluid and there was nothing usual.
The only thing I can find that might be abnormal is this slop. At first I thought it was a worn slip yoke, but after removing the rear driveshaft and testing it again, it was obvious it was the output shaft.
