I noticed when I took off the oil cap and looked thru the oil fill hole, the only oil visible is on top of the rockers. Im not sure how much or little should be flowing thru there with the engine idling. Anyone know?
Psi cold= 65psi
Psi hot=20psi
I have a coming and going single lifter tap every once in a while, And when I added seafoam, as soon as it hit the "bottom" my lifter tapping stopped. (It still comes and goes, just thought it was odd)
Psi cold= 65psi
Psi hot=20psi
