How do my welds look?
Jeep450r
Nor*cal
I had some free time in my auto class, so I fooled around with their mig. Its nice using gas. Here are some pics of my welds.
Welder was a Lincoln 110v 140 amp mig with argon/co2 mix
Please critique my welds. In the pics, I was welding .120 wall tube to 1/4" flat plate.
Any input will be greatly appreciated!
your skipping patter looks like your coming a little too far out of the puddle but looks waaaaaaaaayyyyyyyyyyyyyyyy better than a lot of welds you'll see on here. it looks like it burned in good
Just an observation, but I would spend more time on the plate than the tube. The weld looks like it is mostly on the tube vs the plate, but it could just be the picture. If you took a right angle and put a circle right in the corner, that gap between the edge of the circle and the point of the corner should be where the weld is. I'm sure you know that, but other than that, looks nice!
Side note, what's the heat affected zone on the back of the plate look? How about the tube? I just don't see any on either in those pictures and there appears to be no undercutting of the material. Maybe turn the heat up a tad. Again, just an observation, I'm no pro.
What exactly is "undercutting"?
The HAZ on (in) the tube looks fine, but I don't see crap on the back of the plate (IIRC). Maybe pointing it more towards the plate would help that...
The welding current melts away more of the base material than what is replaced by the filler metal. You really don't want undercut as it is a sign that you're running the machine a little too hot or directing too much of the heat towards the thinner of the two pieces of base material.
Gas isn't like cored wire. You need to clean your pieces prior to welding.
You missed the root of the joint, most of your fillet is on the tube. I suspect lack of fusion to the 1/4 plate. Have you tried to break the joint?
I totally forgot about cleaning it! :eek:
That makes sense. How should I go about trying to break the joint? I don't have a press or anything.
What causes overlap?
big-ass hammer... frustration... combine the two. Works for me every time :roflmao:
Speaking of having to clean the metal before MIG welding, I have a bunch of welds I need to test now... and hopefully not grind out and redo.
Exactly. I should have been more clear. With no HAZ and the way the weld sits, combine with no evidence of undercutting, I'd say the weld wasn't hot enough. Just saying that when I was learning, I'd either have too much amperage and undercut or I'd run it too low and not get the penetration needed to make a solid weld. You'll find you'll have to spend more time on the thicker metal side to get the weld the way you'd like it. Also, pointing it towards the plate might help, but you'll more than likely just pile the weld up without getting any more penetration. Either turn the wire speed down and let the metal heat up more or turn up the amperage.
