Lots of posts about louvers and what potential problems it can solve (heat wise) and what it can cause (water on sensors wise) ... so I just installed a nice set of hood vents this past weekend and hadn't got around to making some drip pans yet. So last night we have a HUGE Thunderstorm and what-not... so as I get out in my XJ this am it fires right up, but the idle jumps up to ~ 2K rpms... slowing drops down to about 1K... but is idling fine. So I get ready to drive it out of my neighborhood and it's shifting horribly, hunting for idle and then finally it just stops moving... still idling ~ 1K but when I'm hitting the gas it's not moving. Almost like my transmission is slipping.
Turn around and idle it back home (1 block), pop the hood and get the air hose out and blow off the 3 sensors sitting around my throttle body. Unplugged and blew them out what I 'thought' was good and dry. Buttoned it back up and it drove better, but it was still shifting bad, missing out a bit and it didn't want to go into overdrive while driving down the street @ about 45mph...
I AM going to fab up some drip pans to help keep these sensors dry, but can anyone tell me which is the likely culprit (sensor) that I may have fried, or that needs to be thoroughly dried out and hopefully work right again? Could it be something on the passenger side of the engine that's causing these issues... perhaps the Coil Pack Wires got wet? I wouldn't think that'd control the transmission shifting, but I don't know everything... ha.
Appreciate the input all.
A couple pics for those who haven't seen them:
