XJ AV8R
- Olympia, WA
I recently did a clutch system conversion on my '91 XJ. During disassembly I found that 2 of the 3 shifter boots were torn. Surprisingly, I didn't find much information on regarding replacement...that doesn't happen very often! I provided a link to my blog where you can check out what I did if you are encountering the same problems. I'm too lazy to post it all here on too. The material cost consisted of a tube of rubber cement. The inner tube I used was free from the local tire shop.
http://xjav8r.blogspot.com/search/label/Shifter Boots
