joejeep92
- Beloit, KS
I have a 92 xj with 4.0 and 5 speed. A while back I started experiencing a few high idle problems. I had trouble with the accelerator cable in the past so I assumed it was that but no dice. It will be fine at idle cold then as it heats up and I drive it the idle increases to sometimes almost 2k but most often around 1500. I have removed and cleaned the iac as well as cleaned out the butterfly valve. Have not removed the whole tb yet though. Anyone have a similar issue?
