Daddycajun117
- Texas
Well Hello I am new to the site and coming full boar with a problem. I purchased an 89 XJ 4.0 from a friend. Well of course it is not perfect. I am having a few problems.
1. I am leaking oil out of the breather on valve cover. OEM has a tube going to air filter box. It seems at idle it is fine but really leaks at higher RPM. I have removed valve cover and cleaned it and the parts in it. Could not locate oil return lines to clean them. Any suggestions??
2. I have no power. It seems at take off it is fine then immediately lags off power.
3. With the power issue it seems to not have a passing gear.
Can any one help me:worship: :huh:
One more problem is oil light comes on at idle even when full. Soon as RPM's up, light goes out.
