DisturbedJeep
- Longview, Texas
For some reason I can't manage to get the board to let me post other than on the chapter forums, but I wanted to let you know that's a sweet pistol. I have the Ruger 22-45 target model in stainless, which is very similar to the one you have. Mine has the bull/target barrel as well.
Just a heads up on the ramp though. If yours is steep like mine, don't try to run hollowpoints through it or the nose of the round will collapse and jam the gun. You can load one at a time, but if you try to let the clip load them it will cause you some headaches.
As for ammo, I've had really good luck with the CCI stingers in a 32 grain copper coated. They're a little more expensive, but worth it as far as factory loads go. Ruger definitely makes some sweet 22 pistols. I'm sure you'll like yours every bit as much as I do mine.
JB
JB
