Hesitation accelerating at highway speed...
xjrookie06
On the last half of a 170 mile round trip the other day, my 96 XJ 4.0 5 speed started to hesitate (and almost stall) while trying to accelerate at highway speeds. It also seemed worse while trying to do that going uphill. That's not a good thing to happen in Atlanta traffic!
It idles fines and accelerates from a stop OK until it hits higher RPM's. Would the vibrations from a long trip knock something loose?
Any ideas on this one?
Is it throughout the RPM range once you get into higher RPM's? Or does it start doing it at say 3000 and stop at 35-3750 rpms?
If its doing it in a specific RPM range, i would check to make sure you dont have leaky injectors. Mine was doing this, basically causing the engine to run lean. I was even getting a backfire in the intake. Check the o-rings at the injectors... its possible you have a leak there.
Hope that helps.
Hallo. Mine 92 had the same problem. After a long search in the motorbay and renewing all the ignition stuf. I find out, there was condenswater in the fuelsystem. I had running the jeep with almost a empty tank. In the future I will full up the tank when it is very wet weather.
Well, of course the next day, I couldn't get it to happen again. I did a 50 mile round trip to run an errand and it didn't hesitate at all.
I'm wondering if I got a hold of some contaminated gasoline, because I got a few gallons the morning of my troubles.
Oh well. Let's wait and see...
Thanks.
