Reverend Jim
- NNJ
I've searched, answer not found. I hope you guys can help. I have a '98 XJ with 4.5" lift and 33's. Lately my steering feels really "tight". It's not binding, it just does not return to center after a turn anymore. I checked the play in the gearbox, that's ok. Had alignment checked, it's in spec. I put the front up on jack stands and greased all fittings to be found. I started it up and turned the wheel, even with no load on the front end it is difficult to turn. Nothing is binding that I can see from underneath, but there is a definite drag on the system. Could this be a bad gearbox or p/s pump? Any ideas on where to look, or other insight to the problem would be greatly appreciated.
Thanks,
Jim
Vehicle spec's: 98 Xj, 4.0l, AX15, 4.5" lift, D30, 8.25, 4.56 gears
Thanks,
Jim
