SubFreq111
- Columbus, OH
So... I have a 2001 and want to swap out the front axle for an HPD30 from a earlier model. So I order from a junkyard a front axle that was allegedly from a 96. I know this is incorrect because it has the center axle disconnect. Not a huge problem, I'll just space the fork so it's always locked. Now it looks like everything else is going to bolt up fine, but then I check out the steering knuckles and they're totally different. They have a setup for a caliper bracket instead of the calipers bolting straight to the knuckles. Now initially I thought I hit the jackpot and this guy had already done a WJ knuckle swap. Every picture of them I find though has two 'levers' on the front of the passenger knuckle, for the drag link/tie rod, but this one only has one, just like my LP D30. I guess I'm going to try to see if the WJ caliper brackets will bolt on, but I was wondering if anyone knew what these knuckles might be from.
https://www.dropbox.com/s/5vnqj9sozosm7se/2012-12-13 14.15.38.jpg
https://www.dropbox.com/s/6p1og4igyqtnqr8/2012-12-13 14.15.15.jpg
https://www.dropbox.com/s/5ogzhqpkr1295xe/2012-12-13 14.15.03.jpg
https://www.dropbox.com/s/3gme1gzdw70tty3/2012-12-13 14.14.52.jpg
